Message 1 of 11
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I just finished making a somewhat complex block (in my opinion) that uses 21 visibility states, 3 lookup tables and a double lookup (thanks to Libbya). All works as it should, but my issue is that I can select combinations from my lookup tables that aren't in my table.
For example, my table has visibility combinations 2+2, 2+3, 3+3, and 3+4 - actual block has more. I can easily select these, however I can also select 2+4 which has no affect on the block as this visibility does not exist. Is there a way to limit my options to only those combination in my table?
Don't want to post my block, but if I gotta, I will.
Thanks for the help.
Jared - Sr. CAD Technician
Words to live by: If it ain't broke, you're not trying hard enough.
