Array Attributes with Dynamic blocks
I made it one block name it as (Sun glass wall), in that added with attribute.(SG-W-01)
I had given array in dynamic block.
while i am dragging the block i wanted the sequence of number with in that block like(SG-W-01,SG-W-02,...etc.,).
I have attached the file kindly check that file & help me out.
natasha.l
Hello @Anonymous,
You could use a attribute definition you would open your block editor & create one or more attribute definitions attaching them to your block.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
I don't know how to use this could you please explain me clearly.
Can you see my drawing, if drag the block will comes continuously but attribute is not coming. but my wish to come attribute also and it will come along with sequence number. like 1,2,3..etc.,
Libbya
It is not possible to array attributes, period.  You can array a nested block containing an attribute and have that attribute display a field value that references its relative position within block editor and use a formula to adjust the value to what you would like it to be.  You lose the ability to edit the attribute value outside block editor, though.  You can also simulate a limited array using visibility states and have the attributes appear based on the distance parameter's length.
