Multiple blocks linked to follow a line
zgambling
zgambling
Hi Everyone,
I'm hoping that some very clever people on here might be able to help me.
I have a number of individual blocks that I would like to join together, but in doing so I want them to be able to "move/bend" at a set point, and also be able to follow a line.
If you can imagine a train with multiple carriages on a train track, that's what I want the 3 blocks to do.
Has any one got any ideas how this could be done.
I use Autocad LT, but have access to Full Autocad.
I have attached a file showing the blocks and line.
Hopefully there are some very clever people who can help.
Zane
Accepted solutions (3)
h_s_walker
Give the block in the attached drawing a whirl. You'll see it's fairly easy to do
Howard Walker
Left Handed and Proud
j.palmeL29YX
See this video.
To convert the Polyline into a spline I used the attached LISP. (There are a lot of other - and better - ways too).
cadder
Jürgen Palme
zgambling
HWalker…. you sir are a legend.
Many thanks for that.
Now if I could get that to attach to he line so that it follows it as I drag it, that would be awesome.
Do you have any instruction on how you managed to do this to the blocks at all please.
I have some other styles I'd like to convert to this type of commands.
Cheers mate
Zane
h_s_walker
Updated the block with an alignment parameter to follow the line for the first block only. You'll have to rotate the others yourself.
As to rotating the blocks all I did was add a rotation parameter to the third block and added that block to the parameter.
I then added a rotation parameter to the second block, added that block to the parameter and added the third block and rotation parameter to that block.
I did a similar thing with the first block, adding the rotation parameters and blocks to the last rotation parameter I created.
Howard Walker
zgambling
Jürgen
Many thanks for this, that's awesome.
Just what I was looking for.
Zane
