I have a dynamic block with stretch parameters and a lookup table. My lookup table is displaying in the block editor but not outside of the block editor. I have racked my brain trying to figure out what is causing this and looked on the forums but cant seem to find anything. Any help is much appreciated. See attached for the block.
Solved by Libbya. Go to Solution.
You have a whole lot of rows that do not have values entered. Because of this, they all have values of zero. Because multiple rows all have the same value, when you close the lookup table it displays the warning that there is 'invalid data for cell - close dialog anyway?' and the lookup grip is not displayed. Fill out the rest of the rows properly or delete them and the grip will display.
So all of those values that do not have data entered will have data. I am pulling the data from an excel sheet. Is there possibly a way to link the data from the excel to the lookup table in order not to have to manually enter all of the data?
