Lookup Action textfield
thomas_schluesselberger
Message 1 of 9
maybe someone can help me out.
I want to have an lookup action where i have multible different choices to pick from.
And i want a title block within a normal text (no multiline text) and the name of the lookup action should always be in the text.
So i can switch from different names from the lookup action.
So as example (see picture) i want to be able to switch with my lookup action from "1" to "2".
I want it to work just like a visiblity state. But i need it to work with a normal text not an attribute.
Replies (8)
Message 2 of 9
h_s_walker
You have no variables in the left hand side. If there are no variables there the lookup will not work
Howard Walker
Left Handed and Proud
Message 3 of 9
Ok, thanks for the info.
But still, i don't know how to get the lookup-name (in the picture "1" and "2") into my text
Message 4 of 9
Libbya
Why does it need to be text rather than an attribute.
Post your block.
Message 5 of 9
h_s_walker
I don't think you can add the lookup "text" into a field. I may be wrong
Howard Walker
Message 6 of 9
Libbya
You can use a blockplaceholder field within an attribute to reference the lookup text.  I am not sure if you can use a field within text, though.  Those are the reasons I both asked why they need it to be text instead of an attribute and also asked that they post the block.
Message 7 of 9
thanks for your answers.
I attached you my block.
The attributes PLANSTATUS and PLANSTATUS1 are my problem.
I have 4 visibility states and there are two different widhts.
I don't really want two attributes, but i need it to be two because at the smaller widht the text must be further together.
So now when i have one of the "Faltrand-Breite - XXX" visiblity states active, i see the "PLANSTATUS1" attribute.
But i don't want to be able to see this attribute (also not "PLANSTATUS" attribute in the other visibility states), i just wanna edit it with my blockpropertytable (or some other sort of lookup action).
Message 8 of 9
Libbya
The only issue is that the attribute is listed on the properties palette?
Message 9 of 9
Well, if you say it like that, it sounds pretty dumb 😂
But yeah, i don't like the workaround here and i would like a cleaner looking option to do this.
That's the reason i asked if it's possible with an text + textfield. But sadly not possible.
