Autocad 2023 Flyout help topic
dvrVSNMW
dvrVSNMW
I got promoted to make our autocad program more efficient. So I want to work with changable blocks. I think it is called FLY-OUT.
It is a small triangle where I can change the layout of a block. Can someone give me a tutorial on how to start from zero with something like this? Cause I need to make some title frames in different languages. I have made 3 different title frames already but how do I make them into 1 block/flyout.
Sorry for my bad enlish, correct me pls if I use the wrong terminologie.
All tips and tricks are welcome.
Accepted solutions (3)
imadHabash
This feature called Dynamic Block .. you can search in the net.
Imad Habash
handjonathan
Hi @dvrVSNMW
Thanks a lot for posting your question to the forums!   Congratulations on the new role 😀
I think you may be referring to a visibility state control within a dynamic block. Below are some links that you may find helpful in getting started.
Info on Dynamic Blocks - Link
Visibility Staes - Link
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
ВeekeeCZ
6 mins video that makes you get started. HERE
