Hi, I am aware, that this topic has been discussed many times before, but I'm still having trouble with it. I made myself a dynamic block of an elevation dimension we use in our country for civil engineering drawings and wanted to make the elevation value automatic based on the position of the block. The problems are:
1. I need the drawing in milimeters and the elevation value in meters (and if I set the field to display the position of some point or line in the block I can't set the conversion factor)
2. for some reason even though I set it up, it does not display the position relative to the current UCS (but i guess to the UCS of the block in block editor.
And currently it stopped showing any value at all, just #####.
How do I set this up?
Sending a DWG file attached.
Thanks to anyone
