Can flip change text?
JasonMartinIndy
JasonMartinIndy
I am wanting to make a dynamic block for switch blocks. Those up or down switches on electronic boards that change how things work. Typically shown as a thin rectangle with a filled in small rectangle showing the position up or down. I can make the flip fine to move the small filled in rectangle from the top to the bottom but what I am wanting is the text below it to change with the flip (ie: off and on). So when I have the switch up the text below it says on, I hit the flip button the filled in rectangle flips to the bottom and the text says off. Is this possible without having to use a separate visibility state to change the text? I can't have the possibility something that says the wrong state. That's why it has to happen automatically.
Jason
AutoCAD 2015, 3DS Max 2015
Dell Precision 5600 - Dual Xeon 6-Core / 2.0Ghz / Hyper 24 cores / 16 gig ECC Ram / 250 gig SSHD / Dual Nvidia Quadro 4000 / Win 7 64bit
Libbya
Post your block.
JasonMartinIndy
Here it is. I left the text out of the block. It is just off and on on top of them selves.
Jason
JasonMartinIndy
Thanks that is super cool. I really appreciate the video. I really need to learn more about dynamic blocks.
Jason
JasonMartinIndy
Where do you get double lookup and triple lookup? I have autocad 2023 but i don't have that. I did have an issue with my block authoring palettes being blank after I upgraded. I got it fixed but I think I had to use last years files to fix it, not sure.
Jason
Libbya
You need to make the tool.  See this thread:
https://forums.autodesk.com/t5/dynamic-blocks-forum/how-to-make-a-double-lookup/m-p/5785708
Be sure to read the parts on BACTIONBARMODE also.
