Limited X & Y move values work using a lookup
blkcar
blkcar
I can get the move function to work using a leader & the lookup table, however the leader base only snaps to the 4 rectangle corners. I would like to have the base of the leader also jump to the mid points of each side as shown in image below.
The extra co-ords values I add to lookup table are not used when moving the leader.
Is this possible? I haven't delved deep into lookup table functionality before so I don't know if this is actually possible or not. If not possible is there a possible better way to achieve the same thing?
I have attached the block below.
Thanks.
Libbya
Yes, it is possible.  Just add the appropriate range values to the lookup1 table to match when you want it to be in the specific locations and match those to the appropriate row lookup properties.  It looks like you already have the appropriate values added to lookup2.
blkcar
I can't find lookup1 table, I feel like I'm missing something so obvious its driving me nuts.
I have turned on the lookup grip, they values I added work when selected from drop down menu, however they still don't work automatically. When moving grip on end of leader it still only defaults to the 4 corners. Ideally I want the lookup hidden & the leader base to move automatically between all 8 points.
I did find this block on the forums & modified it to suit, however I'm not sure how it actually works, maybe that my problem. I recreated it from scratch however it didn't work at all.
What is linking the end of the leader location to relocate the base of the leader to one of the set values?
