I found a block to automatically space @ maximum distance and calculate # of objects, which I modified to serve as a balcony guardrail.
The original block uses constraints and I was able to modify them to my liking, but I'm having trouble finishing the block by somehow linking a new linear stretch action to the original constraint (basically I want to be able to manipulate the block using only 1 grip instead of two)
I'm not sure what the best way to do this is. I figured the best way is with another constraint for the handrail/hatch to follow somehow, but I only have access to AutoCAD LT and can't create new constraints.
I'd appreciate if someone more knowledgeable could help me finish my block, thanks.
