Dynamic Blocks Forum
Is there a way to stop the "Edit Attributes" window from popping up when pasting a new block into a drawings?
3 REPLIES 3
awatson5EJAC
392 Views, 3 Replies
Hi there,
Is there a way to prevent the "Edit Attributes" window from popping up when pasting a new block into a drawings? I haven't come across anything saying that window can be prevented from popping up yet. Attached is an image of what the window looks like for clarity.
Labels (1)
3 REPLIES 3
GeeHaa
in reply to: awatson5EJAC
Try Typing ATTREQ on the command line and set it to 0
Libbya
Change the property 'preset' property of each attribute to 'yes'.  The window only pops up if there are attributes that are not preset.
awatson5EJAC
in reply to: GeeHaa
Thanks for the quick reply / solution!
Autodesk Customer Advisory Groups
”Boost
