Hello, I want to create an intelligent block with 2 attributes. One of the attributes will be used to express a breaker size (a set value such as 100A). I want the second attribute to automatically populate a non-calculated value (such as 1, 2, 3..Etc.) based on what I enter for the breaker size. The purpose is for second attribute to represent a number on a schedule of feeder sizes. I was able to do this using multi-view blocks by following this video instruction made for me by Autodesk support, but I do not like that in order to edit the breaker size I have to go into the extended data properties. I would like to be able to edit the breaker size attribute by double-clicking on the attribute like in normal blocks. Attached is a drawing with a working multi-view block that I created which follows the video's example. The only difference is mine applies to "block references" instead of "schematic symbols". Any help would be greatly appreciated. Thank you
Solved by ojuris. Go to Solution.
The second Attribute is relevant to the breaker size? So 100A will have a tag of 6, and 80A will have a tag of 4, etc..?
hi!
Try to use block properties table - may be it`s OK for You
Juris
P.S.
what is the problem with .dwg files? I can`t attach anymore 😞
The DWG attachment problem has been with us for about two months. Some had it happen later. Not sure when it will be fixed but the host of the Forums is working on it.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Thank you @ojuris. I like using the block properties better than the multi-view blocks for what I am trying to accomplish. I appreciate the attached file also! Splendid solution.
