- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Greetings,
This dynamic block has only stretch and move in it. It has a simple hatch in it which gets stretched. One of our guys inserted a new instance of the block from our network, not from the drawing. The existing blocks in the drawing stayed the length that they had been stretched to but showed only as much hatch as is in the original block. If you stretch any of the existing blocks in the drawing, any length and then back to where they started, the hatch fills back in.
It is easier to do this than explain it.
To recreate,
1. insert this block into one of your borders.
2. Stretch it.
3. Insert the block from whatever folder you are saving it in, and say YES to overwrite.
4. You should see the hatch only filled in as much as the original block.
5. Grab an end of the stretched block in the drawing and stretch it any distance and the hatch fills in.
Question: Is there something I can do with the original block, to stop this from happening? I know that the guy in our office could have just copied the block from inside the drawing or inserted it from the drawing which would not prompt for "Overwrite block", but is there something I need to do to fix the block so it doesn't happen?
Doug
