Dynamic Blocks Forum
Insert block group at current annotation scale from tool palette.
5 REPLIES 5
msuracer10
561 Views, 5 Replies
I have an annotative, dynamic, group of blocks that I have on a tool palette.  The block works great and inserts fine, but it inserts at the 1:1 annotative scale on which I made it, no matter what annotation scale I'm currently using.  Is there a way to get it to insert at the current scale?
Current command string in tool palette:
^C^C-insert;C:/(path)/WeldSymbol.dwg;\;1;0;explode;last;-group;create;*;;previous;;
Also tried:
^C^Cannoautoscale;1;-insert;C:/(path)/WeldSymbol.dwg;\;1;0;explode;last;-group;create;*;;previous;;annoautoscale;-1;
The string above inserts the 3 blocks in the attached file and groups them together, allowing for a single object with multiple visibility grips.
Also tried adding it to the palette as a block and setting it to explode on inserting, which fixes the annotation problem, but ungroups the blocks.
Note:  For the grips to work after inserted and grouped per tool palette command string, GROUPDISPLAYMODE must be set to "0".
Thanks in advance for any help!
5 REPLIES 5
in reply to: msuracer10
Can you not set the auxiliary scale setting to dimscale or plotscale?
That's a crazy way to use groups by the way. Very inventive!
msuracer10
Since it's inserted with a command string instead of using the typical tool palette block, you don't get the option for the auxiliary scale.  I'm thinking that if there's a solution, it's going to be something added in the command string.
I can't claim the idea for grouping dynamic blocks as my own, but it is a really good option if you need to have several visibility states or several dynamic parts in a larger scheme.  I've run into a couple of snags here and there, but it definitely has its applications.
We use the dimscale in our office. You can probably reference other variables as well as per the example:
^C^C(COMMAND "LAYER" "M" "S-ANNO-TEXT" "C" "7" "" "") -INSERT c:/blocks/Dynamic/Dynamic_Box_Shadow;_SCALE;$M=$(getvar,dimscale);\;explode;l;
msuracer10
I couldn't get that to work for me. What does the "$M=$" do in the string below?  Is that from a lisp function or in a script or part of the command string in the tool palette properties?
Forma Design Contest
