Without the problem block being posted, I doubt any here can help you.
R. Robert Bell
wrote in message news:4917504@discussion.autodesk.com...
Ok, my company just got 2006 and all my blocks used to work until i tried
making them into D. Blocks. Now when i insert my updated blocks (on the one
i'm have an issue with, it has a visibility toggle) it comes into the draw
scaled up by 12 and the attributes are scaled by something else that i cant
figure out. the text is the right size but there base points are moved.
the units in the soruce file and the destination file are the same (inches).
when i remove the dynamic properties the problems remains.
if i copy just the block and attri's into a new file and make that the block
file the problems follow.
g'luck on figuring this one out, me nor any co-workers can.
