This should be possible -- can you post an example of what you're trying to
accomplish? Text-and-lines is okay, as long as the idea comes across.
wrote in message news:5429927@discussion.autodesk.com...
I am trying to create a dynamic block so that it rotates through 90 degrees
through a full rotation and that the associated text rotates with it in the
same relative location and always parallel to the view. By this I mean that
if the block rotates through 90 degrees anticlockwise, say, then the text
would rotate 90 degrees clockwise to square up. In standard programing I
would see the 'IF' statement being used. I have two 'LOOKUP' statements and
am trying to get them to work in unison. Can I do it this way or do I need a
LISP routine?
All assistance greatfully received!
