Dynamic Blocks Forum
I need a Lisp to get name of a block by just selecting the block to use it in re insert it without typing it name again
3 REPLIES 3
wael6URAQ
357 Views, 3 Replies
3 REPLIES 3
wael6URAQ
in reply to: wael6URAQ
I found what i was looking for:
(defun c:IBlockA (/)
(command "ATTREQ" 0)
(setq obj (vlax-ename->vla-object (car (entsel "Select block: "))))
(setq blkame (vlax-get obj 'Effectivename))
(command "INSERT" blkame pause 1 ))
I think ADDSELECTED does the same thing. You just have to press enter three times (scale x, scale y, rotation) after placing the new block.
wael6URAQ
thanks a lot very helpful.
Autodesk Customer Advisory Groups
”Boost
