- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi guys. I want to achieve a visibility change effect with visibility and double look up. Detailed requirements are:
1. If the area of the rectangle is no less than 1.5 sm, then the solid hatch is visible
2. If the area of the rectangle is less than 1.5 sm, then the solid hatch is invisible.
as far as I know, I can link the length parameters and visibility parameters with double look up to achieve the effect that when the length is longer than a specific number or range, the visibility state can be changed. But how can I link the area of the rectangle with double look up? I tried to calculate the area with a length and a width constrain but failed to link the result with double look up.
So, is there anyone who knows how to achieve the goal? Thanks a lot.
