Horizontally Scaling Block?
I want to make a rectangular block with fifteen vertical lines, which stretches vertically and horizontally. Is there a way I can do this without fifteen separate horizontal actions applied to each vertical line?
Essentially I want a scalable block but with independent axes.
Thank you in advance,
Karl
Libbya
You could make the vertical lines an appropriately spaced associative hatch.  Scale the hatch and stretch the boundary horizontally.  Stretch only the boundary vertically.
nrz13
@Anonymous
Perhaps you could share some more details about what you're going for.  It sounds like there is a simple dynamic block solution to easily achieve what you want, but I don't know what exactly your end goal is.  Maybe you want an "Array" action in the Block Editor?  You can achieve what you already have without a dynamic block by just using the Properties panel to make adjustments.
See attached CAD file.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
