How to Insert a Dynamic Block and set Parameters (not Attributes) from C#
sanger779DZ
sanger779DZ
If I have a dynamic block that contains several Point Parameters (see simplified example attached). How can I insert the block then set the values of the Point parameters in code (C# preferred not not mandatory).
I have been able to determine how to set Attributes in code, but so far I have been unable to determine how to set Parameter values programmatically.
sanger779DZ
Update: I was able to get a test program working to modify the block parameters, however, if I inspect the block after the code is run the Point Parameters will contain the modified values but the positions of the points in the drawing will not have moved. I tried executing REGEN and ATTSYNC afterwards but no change.
var doc = Application.DocumentManager.MdiActiveDocument;
var editor = doc.Editor;
using (var trans = doc.TransactionManager.StartTransaction())
    var allObjects = editor.SelectAll().Value;
    foreach (SelectedObject obj in allObjects)
        var blockReference = trans.GetObject(obj.ObjectId, OpenMode.ForWrite) as BlockReference;
        if (blockReference == null)
            continue;
        if (!blockReference.IsDynamicBlock)
            continue;
        foreach (DynamicBlockReferenceProperty property in blockReference.DynamicBlockReferencePropertyCollection)
            if (property.PropertyName == "START_POINT X")
                property.Value = 1.0;
            if (property.PropertyName == "START_POINT Y")
                property.Value = 2.0;
    trans.Commit();
