How to constraint two concentric circles, with fixed distance between them?
Hello. My first post, I hope someone can help me out.
I'm trying to make a dynamic block, containing two concentric circles.
First has a diameter of 10mm, the other 12mm.
What I need is: when I change the size of one of them, the other has to stay at the same distance of 2mm.
Thanks in advance.
Libbya
Post your block file so people trying to help you don't need to start from scratch.
Libbya
Regardless, you could fairly easily use constraints but I wouldn't use any constraints for this unless this is part of a larger block that for some reason requires constraints to work.  Here's how I would do it.
*edit*
That is a great solution! Thank you Libbya for the effort. Well appreciated.
Best regards.
ndikesh
Hi Libbya, i just tried your method and i'm not sure what i did wrong but i couldn't get the result.
i've attached my block, can you please have a look.
thanks in advance.
h_s_walker
Turn off the grips for DISTANCE3 and DISTANCE4. Those grips are taking priority over the DISTANCE1 and DISTANCE2 grips. You do not need those grips since DISTANCE3 and DISTANCE4 are chained to the DISTANCE1 and DISTANCE2
Howard Walker
Left Handed and Proud
