Dynamic Blocks Forum
How to add a Dynamic rotation to this block?
5 REPLIES 5
martin.hong
349 Views, 5 Replies
Hey all,
I managed to create a 3D (ish) dynamic block for a fence that can stretch and change the post height, but I just can't figure out how to add a rotation parameter/action to it... The block was built with ucs x axis at 90 degrees (in order to apply dynamic actions to it), so it may not be possible. However looking to see if any of you gurus would be able to find a creative way how!
I've attached the block in this post.
Thanks for all the help...
Labels (1)
5 REPLIES 5
j.palmeL29YX
in reply to: martin.hong
Why not rotate the block reference(s)? You don't need an additional rotation parameter and action - and it is also not possible to add these (they had to reside in a 90°rotated plane, but dynamic parameters/actions work in one plane only)
Jürgen Palme
martin.hong
I could using 3d rotate like you said (really helpful command!), but the problem arises when I need to rotate it again after it's been rotated and I can't align it to a specific angle/line since I can't find a way to reset the rotation back to 0. If there's a way to set the rotation back to 0 after rotating, that would solve the issue...
Libbya
I've used multiple dynamic blocks with their XY plane rotated so that the dynamic actions work on a plane other than the WCS XY plane.  Whenever I need to return to that custom plane, I just use the UCS command and select points on the block to define the plane.
j.palmeL29YX
No, to rotate the block reference you don't need a 3D rotation, but the normal 2D command "rotate". And if necessary you can use the option "Reference" to type or show a referenz angle.
Jürgen Palme
martin.hong
in reply to: j.palmeL29YX
The Rotate "Reference" worked for me. Thanks!
Forma Design Contest
AutoCAD Beta
