Message 1 of 13
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
can I make this corner modular? Like making it change from 45 to 46 to 47...
Yes, probably.
Post what you have and some examples of what you want it to do, range limits, etc.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
I'd want to have these angles, with dynamic stretch on the tube
Here's a quick sample of what you could do.
The linework is two rectangles and two arcs. I used Auto Constrain to lock most of the geometry together. Then I added some dimensional constraints to make some parts of it adjustable and/or lock its value.
Mark Mccall
CAD Mangler
For the angles you listed, edit the properties of rad1 to have an increment of 5, a minimum angle of 25 and a max of 90.
Mark Mccall
CAD Mangler
thank you so much, is it possible to make with more than one curve too?
Yes ... but my version gets a little weird. Some of the grips get displaced. Its not elegant but it works. It probably has something to do with my initial construction and application of the geometry constraints.
Mark Mccall
CAD Mangler
Some small improvement attached.
What do you mean with "more than one curve"? I could imagine several interpretations. Show an example please.
Jürgen Palme
i meant more than one curve in one pipe
Something like the here attached?
Jürgen Palme
yes, however it's not really working for me.
when i try to mess with the parameters its says ''one or more constrained cannot be resolved''
i figured it out thanks
