Hello all,
can someone please help me to create a dynamic block or a lisp command that will create block like given in example. The dynamic block or lisp command will draw me the foundation based on the chosen points and data that i would enter in the command line.
Please take a look in file for explanation.
Thank you for your help and time
Check the attached attempt. Does it meet your goal?
The values A, B, C and D can be changed in the properties window.
(I don't understand what you mean with "THE BLOCK MUST WORK AS A MIRROR VIEW TOO, IF ANGLE OF PILLAR LOOKS LIKE THIS " / " " . Would you explain please more clearly?)
[EDIT]:
[I found a small error. Attachment deleted. I will get back shortly]
Jürgen Palme
Hello thanks for reply,
Actually, we don't understand each other.
and one more better explanation
with points define on top and botom of axis line the total vertical height of the foundation is defined and slope of axis and pillar
When you change value C the heigh of pillar will change, the slope must stay as defined with points
when you change value D only botom rectangle will change. the vertical height between top and botom point on axis line must stay as defined before.
I've had in my mind a rough solution idea similar to to the one which i posted in a prior thread. But in your model I don't get that to work. Sorry, I can't help you.
Jürgen Palme
