Dynamic Blocks Forum
Help for column dynamic block
3 REPLIES 3
mayurrotithor
284 Views, 3 Replies
I am trying to create a dynamic block of column so that I can have only one column block and it can be stretched as per dimensions. But I can't lock the insertion point at the insertion of the cross lines of the square column.
3 REPLIES 3
hwalker
in reply to: mayurrotithor
Is it an elevation of a column? If so have the block in the drawing below on me.
The dots appear at the centre of each face and an extra set of dots appears at the centre of all faces added together.
The floor level can be sized as well in the properties.
Howard Walker
Left Handed and Proud
Libbya
Post the file.
This concept may get you close.
-Tim
Forma Design Contest
AutoCAD Beta
