Have subcategories within a lookup table
tellis
Message 1 of 9
tellis
Hey guys,
So I've seen it before where you can click your lookup table, opening the drop-down menu, it will list off a few things (my example would be G.W.B, Plywood and Fiberboard) and then you can scroll across to select the size you wanted for that item.
IE
Gypsum
 --> 1/2"
 --> 5/8"
 --> 1"
Plywood
 --> 1/4
 --> 3/8"
 --> 1/2"
Fibreboard
 --> 3/8"
 --> 3/4"
 --> 1"
How does one make this happen? I can only seen to get the lookup table to do the first part of selection g.w.b, ply or fibreboard.
Replies (8)
Message 2 of 9
imadHabash
>> how does one make this happen? <<
if i understand you right,we call this dynamic block which you can reach to it from block editor (see attached).
Imad Habash
Message 3 of 9
tellis
My intent would be to have something like this but with a lookup table
Message 4 of 9
Libbya
You can do that with a block properties table, but not with lookups.  You will need a separate lookup/grip for each sub-table.
Message 5 of 9
ojuris
why not to use block properties table?
Message 6 of 9
tellis
Ah OK. I'm not very familiar for block properties tables, so I was aware that's how that can be done. I'll do some Youtubing and learn!
Message 7 of 9
m_rogoff
See attached.
In block editor, create a "fake" attribute and set it as invisible
Create a Block Properties Table
Double click on the B.P.T. icon and hit the Add Properties button on the top right (+fx)
Select the attribute and the linear dimension for the thickness
Enter text in the attribute for each condition, with the corresponding thickness in the adjacent column
Message 8 of 9
m_rogoff
The last video I posted used an attribute for the sub-category. I realized this is an Acad LT limitation. In full Autocad, use the button in the attached pic to create the sub-categories
Message 9 of 9
tellis
Thank you for your time, but I have since learnt how to use the Block Properties Table and fixed my issue. Thanks though.
