Hatch dynamic block lock on 2 sides
I have a question about using a hatch with a dynamic block. I want to make a library, with blocks that we use a lot. We want to make a universal block. That we can stretch length and width wise, so we don't have to make a block for every measurement that we possibly need. We also need a hatch in these blocks, but voor instance the block voor isolation we need a specific hatch. So in the ideal situation we can lock a hatch the the line around it, but only for the width.
In the screencasts i put a picture, the first block is with the right hatch that we need with every width. But the block on the right is when i stretch it.
So long story short. Is there a solution to lock on the left en right side of a hatch to the boundary, so the hatch will stay in place when we stretch it?
steven-g
Your hatch should be created as associated with the object it is hatching, there are no special settings available in a dynamic block for hatches, just the properties of the hatch generally. What exactly do you need to lock, if the hatch is associative then it will automatically stretch with the polyline/line boundary. Or do you need it to behave in some special way?
