Hatch Associate in dynamic block
fkp7057
fkp7057
Dear All,
I need small help to finish my dynamic block in my block every thing works fine.
I have added multiple hatch in this block & and using it in viability perimeter.
now my problem is that hatch not updating its shapes based on other perimeter which i have sets.
any help and suggestion appreciated .
refer attachment.
FKP
j.palmeL29YX
- Remove the hatches and the two arcs (which are part of the hatch boundary).
- Draw a polyline (2 lines and 2 arcs) as new hatch boundary.
- Add the required constraints and dimensions to fix this polyline at the right position
- Create the hatches. But don't pick an internal point. Instead choose "Select objects" and choose the new drawn polyline.
- Complete the blockdefinition ...
If you don't get it to work I can show you later an example (at the moment I'm in a hurry).
Jürgen Palme
fkp7057
Thanks for your advice but i already found the solution..
using recreate hatch boundary and i have applied auto constraint on that boundary and other part of the block.
regards,
FKP
