Halo Text in Block as Attributes
Message 1 of 1
I thought I would try this forum since there wasn't any response in the developers/ LISP forum.
I have a block I acquired that will give text a halo around the text characters. This is used for placing on top of aerial images and the like to help readability. The many layers of text within the block are attribute text entities.
I have symbols with attribute text that must be overlaid on the aerial image. Is there a way to combine the Halo text block (or its attributes) into a block and use it as the attributes that can be added in a batch routine using a script (.scr) file?
I have attached the Halo text block and a sample script file that can be generated from Excel.
Replies (0)
