Grip Position after Linear Stretch on both side from center
Hi there, I created a stretchable rectangle where the insertion point is located at the center.
I want to stretch the rectangle with 1 grip at the right side so that the both side of the horizontal length of the rectangle would be equal to the stretched length of the linear parameter.
I tried to add linear stretch action at both side with distance multiplier 0.5 and -0.5. but the grip would not follow the outline of the triangle. However, changing the distance multiplier to 1 and -1 would fix the grip shifting problem but the horizontal length would be doubled.
So, if anyone could suggest a better way stretch? Thank you.
Libbya
Wow, this is the first time I saw the correct procedure to stretch from midpoint rather than the Start Point.
Thank You so much!
