need to array/move an object inside a dynamic block
matthew_neesley
matthew_neesley
Hello to all:
I have a challenge that I'm struggling with.  Please see the attached dwg.  I need the small blue polyline to move/array with the stretch command built into this block.
Also, this is a part of a much larger, more complicated block, and I need to do the previously mentioned task WITHOUT Visibility States or a block table...those parameters exist already in my Master Block and cannot be used for this specific task.
Description:
at 24" long, non-stretched state:
-the blue pline doesn't move
at 48" long stretched state:
-the blue pline moves 24" to the right
at 96" long stretched state:
the blue pline previously moved is also arrayed once 48" over
at 144" long stretched state:
the blue pline previously moved is arrayed TWICE 48" over
Anyone have any brilliant ideas?  I've tried all sorts of lookups, move actions and array actions, and I can't get it.  Thanks in advance for any replies!
Libbya
I think there are various ways it could be done, but I think this is the simplest and easiest to implement.  See screencast:
Libbya
Screencast didn't post.  Here it is again:
acadadmin3KNUF
Awesome!  Stupendous!  Magnificent! 😁
