Give dynamic array distance a variable length
ohalloba
Message 1 of 15
ohalloba
Hello everyone,
I'm trying to create a "bifold glass door" dynamic block that can be arrayed, but the door can also be adjusted to different sizes and still be arrayed while being attached. When I use an array it only allows me to pick a static distance. I was wondering if it was possible to change that static distance to a variable depending on the glass door size.  Thanks!
Replies (14)
Message 2 of 15
j.palmeL29YX
Post your block please.
Jürgen Palme
Message 3 of 15
ohalloba
  I'm trying to make it so no matter the size you stretch it, the windows will always array the length of the window. I'm relatively new to dynamic blocks.
Message 4 of 15
j.palmeL29YX
Are you looking for something like >>this<<
Jürgen Palme
Message 5 of 15
ohalloba
Thank you so much for creating the block, but I'd love to know the steps for the future if it's not a bother. Thanks again.
Message 6 of 15
j.palmeL29YX
My first attempt above was not well designed, therefore you find here attached an improved version.
The main principle: As far as I know it is not possible to modify the source object(s)  of an array inside a dynamic block. But in the current case you can create a dynamic array and hide the unwanted parts of the middle line behind a wipeout. You can follow the detailed steps in >>this video<<
(I'm afraid it is not easy to understand. If you have further questions, ask again).
Hint: In the current version the user must ensure that the Length overall must be greater than the 2*Width (or the Width must be smaller than Legth/2. In a later version this can be included in the block definition).
Jürgen Palme
Message 7 of 15
ohalloba
Amazing video and I'm following along nicely, but at the part where we have to array the 2 rectangles on a path, I get an error saying "A dimensional constraint or user variable with an expression has been set to a numerical value." And deletes the "Width" dimension on the top, but I'm following your instructions step by step.
Message 8 of 15
ohalloba
before arraybefore arrayAfter arrayAfter arrayas I exit arrayas I exit array
When I copy and paste your block into my drawing that message pops up again and ruins the block
Message 9 of 15
j.palmeL29YX
At the latest before creating the array set the system variable DELOBJ to 0.
(After creating the array you can set DELOBJ back to the value of your need).
Try if that helps and let me know. (I'm not yet sure why that "When I copy and paste your block into my drawing that message pops up again and ruins the block" happens. )
Jürgen Palme
Message 10 of 15
ohalloba
I got everything working, thank you so much!
Message 11 of 15
heretic2k
Community Visitor
Community Visitor
You can use constraint parameters to achieve your ideas
Message 12 of 15
heretic2k
Community Visitor
Community Visitor
Message 13 of 15
j.palmeL29YX
@heretic2k
Obviously this suggestion refers to another thread ( ?).
But regardless of that, allow me a few hints:
- You forgot a coinzident constraint.
Now it works.
- Next: I'd suggest to constrain as much as possible using geometrical constraints. As example: you can (and should) delete all the dimensional parameters, which depend on W (d1, d3, d5, d6, d7). Use "Equal" constraints instead. The same for all dimensions depending on T.
- Additional: For all those dimensions that may be necessary but should not be controlled by the user, don't use dimensional constraint Parameters (bcparameter command). Use instead suitable dimensional constraints (one of the dc... commands). (In the current example we don't need such dimensions)
Bonus: For fun I added an angular constraint to open/close the door.
My 2ct only
Jürgen Palme
Message 14 of 15
laurenyy
Community Visitor
Community Visitor
Thank you for the video.  I am stuck at the part where you enter "floor" for d2 dimension.  Where is the "floor" variable defined?
Message 15 of 15
j.palmeL29YX
floor is a mathematical function which rounds down a numerical value to the next Integer.
Snip from the help:
Jürgen Palme
