Message 1 of 10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have made this dynamic block for a double and triple paneled bi-fold door but will be making all the way to 8 panes eventually, it is all working kinda. The 2 pane works great, each pane stays the same width. For example if i set the width of the block to 6060mm (30mm frame on each side) each pane will be 3000mm. I have applied the same knowledge to make the 3 pane version, it works, however each pane is a slightly different length when stretching the block. Its only out a few mm over a big span and it wont be noticed on drawings at 1:50/1:100. However because i am a perfectionist i would like them all the same length.
