I did a stairs dynamic block with the visibility options for:
U shape - 3flights & 2 flights; L shape; and I shape - 1flight & 2 flights.
Beside this, I would like to give the option to reverse the stairs arrow orientation (therefore the flip).
However, after flipping, some of the arrays and stretches start creating conflict.
In order to avoid the use of a flip, is there a way to create an extra visibility mode with the arrow opposite direction and show it in a separate dropdown menu? I guess something like a lookup to complement visibility. I gave it a try but when changing the lookup menu, it also changed in visibility.
I'm a bit lost with it and appreciate any help.
Thanks!
Solved by hwalker. Go to Solution.
Something is wrong with your DISTANCE5 parameter. I turned off the grip on it and instead turned on the grip for DISTANCE7 and it worked as it should.
Same with the two flights visibility state.
Howard Walker
This is a cool block. Do you think there is a way to modify it so that you could adjust the tread depth?
