Finding by attribute value - dynamic blocks
I placed in the drawing an amount of dynamic blocks - rectangles of adjustable size. The blocks have 6 attributes - first 3 visible, last 3 unvisible. I'm trying to search by value NAME (unvisible) but it doesn't work. Could you tell me what is the reason? I used the dynamic blocks for the first time. It seems that the find command does not work for invisible attributes, which would be quite a shame... because I want to search by one of the invisible attributes.
Thank you for your help,
Magda
vinodkl
FIND would include the invisible attribute as well in search.
Can you check the search options in "FIND" is similar to how it looks like at my end.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Thank you so much. You made my day!
In menu there is the option 'Ignore hidden items' and I had it checked before.
Thank you again.
eng-msmohamed
good day,
                    How can I make this if I used the insert field option in attribute text?
