dynamic block rotate problem
hey, i am making a dynamic block its kinda hard to explain so ive attached my block. i need to be able to change the angle of a corner. i wanted to use rotatate but then i cant keep the rounded edge connected. does anyone have a solution?
thanks in advance
vinodkl
Can you please check again, the file is not attached.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
oops it should be there now
whoops
vinodkl
I was not able to find a perfect solution for this, but found a band-aid solution by adding wipeout.(set the system variable WIPEOUTFRAME to "0") See if this helps.
i decided to just make the corner straight, that isnt really a problem and i think te easiest solution
