- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Is it possible to put fields in a dynamic block in such a way that the field value would be controlling the action of the dynamic parameter?
I am basically trying to create a custom property in Sheet set manager named north pointer angle. This custom property is meant to define the direction of the north pointer with respect to the positive x-axis. Now I am planning to link this value to the north pointer in each drawing sheet format. the north pointer in the sheet format is a dynamic block which has a rotate parameter assigned to it. the rotation angle is supposed to come from the value given in the custom property of SSM.
the idea is that I only need to set the north pointer angle in the SSM and all the drawings in the whole project would always indicate that same value. this way, I won't be needing to set in each and every drawing.
can someone throw light on this? Thanks in advance.
