Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Field in the attribute counting array
kamil_pajakH724R
Message 12 of 17
kamil_pajakH724R
I have a block that serves as a shelf. The shelf has modules, and I'd like it to count and display the number of modules automatically. I've tried the and field attribute, but it seems to be disabled. That is, after I confirm it, it becomes plain text. Please help, I'd like to understand exactly how this is done. Perhaps I have some settings or properties in AutoCAD that cause the field to be converted to text. I'm attaching a video.
Replies (16)
Message 1 of 17
kamil_pajakH724R
Hi, I'm revisiting an old thread because I can't seem to figure it out. Could someone explain this to me step by step?
Message 2 of 17
CGBenner
@kamil_pajakH724R
Hello and welcome!  Can you share some more detail on exactly what you are trying to accomplish, since this is such an old thread and the software has probably changed a lot.  Can you also share what version you are using of AutoCAD?
Chris Benner
Message 3 of 17
kamil_pajakH724R
I've created a block that acts as a shelf. I'm adding subsequent shelf modules using an array. I'd like to automatically display text with the number of subsequent modules. AutoCAD version 2024.
Message 4 of 17
MMcCall402
Set the value of the attribute to be a Field that uses a formula to calculate the number of shelf units by dividing the value of linear parameter used for the array, Distance1, by the length of one shelf unit.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
Message 5 of 17
kamil_pajakH724R
I don't understand, I'm doing something wrong. When I add a field, after confirming it, it disappears when I reopen it. It's different for you. I've attached a video.
(view in My Videos)
Message 6 of 17
kamil_pajakH724R
Perhaps some properties? I noticed that your unit factor is 0.001, while mine is 1. The same goes for Scale X, Y, and Z – mine are all 1, while yours are 1000. The most puzzling thing is the disappearing inserted field, which can't be edited later.
Message 7 of 17
MMcCall402
Use the BlockPlaceholder for the value of Distance1 in the formula.
Also, be sure to run ATTSYNC when you edit the attributes within the block editor to resync the inserted block with the revised block definition.  (I sometimes even insert a brand new one just to make sure there isn't some mismatched flaw)
Mark Mccall
CAD Mangler
Message 8 of 17
kamil_pajakH724R
Am I doing it right now? I'm using attsync and inserting a new block. It only shows hashtags.
(view in My Videos)
Message 9 of 17
kamil_pajakH724R
Could you record your screen while you do this?
Message 10 of 17
Brock_Olly
Instead of blockplaceholder, try Object > green button, select the distance parameter.
use that in the formula field, you should immediately see the actual value instead of ####.
Message 11 of 17
kamil_pajakH724R
The main problem is that my field "disappears." The field always has a background. After validation, my field becomes plain text and cannot be edited.
Message 13 of 17
kamil_pajakH724R
I have some interesting information. What I'm doing was in AutoCAD 2024. I tried to do the same in AutoCAD LT 2024 and it worked. The difference between these versions is that I have the educational version of AutoCAD 2024, but AutoCAD LT 2024 is commercial. Could there be a difference here?
Message 14 of 17
CGBenner
@pendean any thoughts on this, is it true that what the OP is doing would not work in an educational version of Acad?
Chris Benner
Message 15 of 17
pendean
Community Legend
Community Legend
@kamil_pajakH724R @CGBenner Not possible, EDU variants are fully functional just like commercial licenses.
Message 16 of 17
MMcCall402
I followed along with the video exactly and it worked on my end.  (using Civil 3D 2024, not that it should matter)
There was one thing I noticed in the video. After entering the formula and pressing the "Evaluate" button the formula changed to a bunch of syntax.  I didn't get that on my end. The formula stayed the same. The only change was some additional formatting was added to the Field Expression area.
Mark Mccall
CAD Mangler
Message 17 of 17
kamil_pajakH724R
I couldn't figure it out until today. Until I finally found this thread.⬇️⬇️⬇️
https://forums.autodesk.com/t5/autocad-lt-forum/fields-turning-to-text-automatically/td-p/11390825 - A little while ago, I had to enable "Use Unicode UTF-8 for worldwide language support" in Windows to try something, but I didn't disabled it afterwhile. That seems to be what caused the problem.
incredible! 😆
