Examples for 'Flow Chart' dynamic block from the Design Center
I'm willing to look elsewhere for educational purposes, but can't find anything. Does anyone use the dynamic block called 'Flow Chart'? I was wandering around the Design Center looking for stuff I could use, and came across this 'Flow Chart' block in Dynamic Blocks/Annotation - Imperial/Blocks. If you've found a use for it, could you post a picture or file? Thanks
timothy_crouse
There are some basic flow chart objects in the AutoCAD palette, Ctrl + 3
Or see attached objects too.
Best Regards
-Tim C.
