Error in lookup when reset
S_S_SS
S_S_SS
Hello every one ..
I made a dynamic block with visibility and double lookup
but when i reset the block it makes error
it make that
but it really that
the name of the lookup parameter changed
and also when i rotate it change the lookup parameter also
i uploaded the drawing
and i need some one help me about that
thanks in advance ....
h_s_walker
A good rule of thumb is if you have a double lookup is to make sure it is visible in every state.
Talking of double lookups yours is the problem. You've got your references the wrong way round in Lookup 2
It should be
1-1
1-2
1-3
2-1
2-2
2-3
And not
2-1
2-2
2-3
1-1
1-2
1-3
Howard Walker
Left Handed and Proud
S_S_SS
thanks sir
i solved but i can't understand what was wrong about that
when i write what you said it works correctly but (plan & elevation) lookup view reversed and i changed lookup04 and made
plan to 2000 and
elevation to 1000
to work correctly
can you explain what's the difference sir please ??
h_s_walker
@S_S_SS Your block is a bit complicated. I've made you a new one it only uses 2 visibility states and stretches, and the advantage with this one is you can add different lengths quite easily.
For multiples of 3000 Distance 2 needs to be 150, for multiples of 4000 it needs to be 187.5 and for multiples of 5000 it needs to be 100
See the attached drawing. Just be aware that you need to do a regen for the number to update
Howard Walker
S_S_SS
thanks sir
your solutions are great ..
