Is there a way to create a block like this?
ottosson_mathias
ottosson_mathias
I want to create a block with let's say 5 invisible rectangles with an attribute text inside each. And when I write something in the attributes the rectangle around the text becomes visible. If the attribute is empty the rectangle should stay invisible.
This is how it should look like when I only write something in the first attribute:
Adding text to the rest of the attributes reveals the rectangles/cell walls
Is this possible to do at all somehow?
Thanks!
ojuris
As far as I know I think that it is not possible automatically
but you can use something like that - see attached
ottosson_mathias
Thanks! That's definitively a nice way to do it.
I'm very inexperienced when it comes to dynamic blocks, but could the Distance1 property be changed with script?
ojuris
I think it is possible but I won't be able to help with this
