Editing blocks with attributes
Hi everyone. I need someone help with this issue. I want to create a block (block "A") with 3 blocks inside. Each inner block has attributes and I have already lisp routines to edit those attributes. If I want to change the scale of the block "A", this one cannot be exploded. Please, help me.
THANKS!
peterjwinberg
Use the SCALE command?
jayhar
Please Clarify your Question ones again.
<<<<<<If I want to change the scale of the block "A", this one cannot be exploded. Please, help me.>>>>>
I think, would you like to create Unexploded block, that means nobody edit your block. is it ???? (its impossible)
or
You are telling, "this one cannot be exploded" but already have lisp routines also.
Here some Examples:
1, Enter new value for BLOCKEDITLOCK <1> No body can edit blocks only in your system
2, Find the attachment "Type 1", try to explode or open. ( Block are created with Attribute)
3, "BURST" command only works for attribute-values within block-insertions. (if Allow Exploding is Yes)
4, "BURST" command did not work in LT version.
5, Find the attachment "Atd2Text" attribute convert to Text
6, Open Block editor > Properties > Below Block > Allow Exploding Yes/No
<<<<<Each inner block has attributes and I have already lisp routines to edit those attributes>>>>>
Please Upload lisp.
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
