Attached files ,
if you open the file it will be already disappeared , so i uploaded the video
thanks for reply
Check this link, if it resolves your problem.
Cheers,
Vinay Vijayakumaran ![]()
The default value for fps is <5>. Keep it the same.
Some other settings which can speed up autocad you can find it on this link
http://www.thesourcecad.com/improve-autocad-performance/#comments
Please reply if your issue is solved.
Cheers,
I think it is due to the block from an external source which is making the issue.
Since I don't have the block library for me its occuring like this. (Without the legs)
Have you tried disabling or enabling your hardware accelaration? GRAPHICSCONFIG
Cheers,
