Delete Additional Format from Dynamic Blocks
  I have a drawing with hundreds of a dynamic block which contains attributes for Width and Height.  The default value of these attributes in the block itself is blank.  In each instance of the block the value of these attributes is linked to the Width and Height field from that block reference, with an additional format of a " suffix for inches (eg value is 12 1/2 with a " suffix to make it 12 1/2").
  My question is how do I go about deleting the suffix from all of these blocks?  Because the attribute values have been entered in each instance of the block and not in the block itself I cannot do it through the block editor.
Thanks in advance.
Sujan.Maharjan
Try this
Select your blocks. Type FIND command . Then REPLACE ALL your suffix with blank.
I hope this helps
"Revit Lies in the tension between what we want to do and what can be done!"
