Dynmic Blocks getting disappear in 3d view
Message 1 of 9
conceptual view
Replies (8)
Message 2 of 9
Vinayv4v
Can you please upload the drawing file for review.
Cheers,
Vinay Vijayakumaran
Message 3 of 9
Attached files ,
if you open the file it will be  already disappeared , so i uploaded the video
thanks for reply
Message 4 of 9
Vinayv4v
Check this link, if it resolves your problem.
https://goo.gl/UdNKyZ
Cheers,
Vinay Vijayakumaran
Message 5 of 9
will check, currently the fps is 5 , should i reduce it 4or 3 or should i increase it
thanks for the reply
Message 6 of 9
Vinayv4v
The default value for fps is <5>. Keep it the same.
Some other settings which can speed up autocad you can find it on this link
http://www.thesourcecad.com/improve-autocad-performance/#comments
Please reply if your issue is solved.
Cheers,
Vinay Vijayakumaran
Message 7 of 9
still the issue is there ,
Message 8 of 9
i am thinking whether it is a problem with layers.
the issue is happening only when i am creating a 2d view of the same in thw layout
Message 9 of 9
Vinayv4v
I think it is due to the block from an external source which is making the issue.
Since I don't have the block library for me its occuring like this. (Without the legs)
Have you tried disabling or enabling your hardware accelaration?  GRAPHICSCONFIG
Cheers,
Vinay Vijayakumaran
