Dynamic Title Blocks
paul_cushion
paul_cushion
I remember seeing somewhere, a tutorial about Dynamic Blocks and they touched on a Dynamic Title Block.
My questions is, How was that set up?
I cant find anywhere about how to program a title block to have a pulldown that would adjust a company's mailing address, and in our case, a CAGE CODE number.
Is this done using an excel spreadsheet?   How is it linked to the title block?
One of my own personal goals has been to create a title block that is "adjustable" - for lack of a better term - to where the design center is.
Paul Cushion
Sr. CAD Designer
MACOM
lakshmankumar.satya
Use attributes and make them block.Set Parameters as per your requirements in block.
cloweRE8TC
I use custom fields for my title blocks, it makes things easy to fill a lot of details in using drawing properties.
MMcCall402
You could make the values of the attribute as fields to pull values from the Sheet Set Manager and let the SSM supply the info to all the title blocks in the set.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
