@Kyle.para wrote:
The dynamic stretch parameter is not working for some of my blocks. Sometimes I can get is to work other times I cannot.
I am wondering if something is wrong with my setup. I want to be able to stretch the block with the dimension using the properties window.
The block will stretch fine manually, but as soon as I stretch it with the properties window it stretches the distance like it's suppose to.
However, it doesn't stretch the objects. I have attached one of the problematic blocks in question.
You haven't provided enough information so I'll just assume you want the block to only stretch downwards and go from there. The linear stretch startpoint should be located at the top and a single grip at the bottom.
Look closely at your block and you should see a little yellow box with the exclamation point in it - that is a clue you have a problem. You have 2 grips and only one action assigned and it is assigned to the startpoint which works to manual drag with the cursor but not when entering to the Properties palette.
Take a look at the attached revised block - note the changes allow manually entering the distance in the properties window and a manually drag of the grip in the same direction. I'll leave it up to you to figure out changes needed for the hatch and line work.
