Change shape
Change shape
Change shape
Hi.
I am currently in need of a Block that kan ”change” shape.
I would like a standard Block that i kan use for all type of componentents in a drawing.
I have created a block with attributes. So far so god.
I would then like to be able to turn on the wanted triangle in this block in ”Enhanced Attribute Editor”.
If this should be done by a checkbox or by typing A, B, C etc. in a text field (TAG), i don’t know.
In addition to this i would like to be able to export this information by using ”Export Attribute Information”.
Then i could change values (triangle direction) in exported data and then use ”Import Attribute Information”
Pictures below is how i pictured it.
Don’t know if this is possible.
Any thoughts. J
Have a nice day.
1:
2:Billed 1.jpgBillede 2.jpg
Why not just use visibility states? Data extraction will be one way to export the information based on which visibility the block is in. I'm not too sure how to handle the importing though.
Hi Devinhdl.
Sorry about the late respons.
This solved one of the problems. Thanks. 🙂
Now i have to figure out how to handeling import.
Have a nice day.
