I would like to create a dblock that provides a
percent slope is it possible?
Solved by ojuris. Go to Solution.
See the attached drawing
Howard Walker
And i would be able to rotate that block and acording to the rotation i would give me the slope
I'm not sure you would be able to get the block to work out the slope using the actual block angle, but here is an updated version of my previous block using just an arrow
Howard Walker
see attached
1. rotate with dynamic action
2. rotate block
3. both options together
@ojuris How did you do those last two. I had to convert the drawing to LT2016 and even though I can see those last two are fields. They don't show up as fields in the block editor.
Howard Walker
for block 3 I add attribute BB and add Field in BLock editor mode - see attached
Good Morning, I am new to dynamic blocks, and would like to create one that has similar functionality to this dynamic slope block, but for a 3d ground model. Ie have 2 movable grips to define the start and end of your gradient, have CAD read the Z values and distance to calculate a gradient between (Gradient 1:xxx) is this possible? Can someone help please?
