Dynamic Blocks Forum
Dynamic slope block
11 REPLIES 11
Message 1 of 12
david_malikHKP4F
741 Views, 11 Replies
Dynamic slope block
I would like to create a dblock that provides a
percent slope is it possible?
Tags (1)
11 REPLIES 11
Message 2 of 12
hwalker
in reply to: david_malikHKP4F
See the attached drawing
Howard Walker
Left Handed and Proud
Message 3 of 12
Thak you but i would like to create somthing like this
Message 4 of 12
And i would be able to rotate that block and acording to the rotation i would give me the slope
Message 5 of 12
hwalker
I'm not sure you would be able to get the block to work out the slope using the actual block angle, but here is an updated version of my previous block using just an arrow
Howard Walker
Message 6 of 12
ojuris
see attached
1.  rotate with dynamic action
2.  rotate block
3.  both options together
Message 7 of 12
Thank you that was exactly what i was looking for
Message 8 of 12
hwalker
@ojuris How did you do those last two. I had to convert the drawing to LT2016 and even though I can see those last two are fields. They don't show up as fields in the block editor.
Howard Walker
Message 9 of 12
ojuris
in reply to: hwalker
fields in attributes I add in drawing mode not in block editor mode
Message 10 of 12
ojuris
for block 3 I add attribute BB and add Field in BLock editor mode - see attached
Message 11 of 12
Good Morning, I am new to dynamic blocks, and would like to create one that has similar functionality to this dynamic slope block, but for a 3d ground model. Ie have 2 movable grips to define the start and end of your gradient, have CAD read the Z values and distance to calculate a gradient between (Gradient 1:xxx) is this possible? Can someone help please?
Message 12 of 12
j.palmeL29YX
in reply to: AlexKDJ24
>>click<<
and the there following posts
Jürgen Palme
Autodesk Customer Advisory Groups
”Boost
